Need a service manual for GE built Crosley dishwasher Mod# XDT500PSP4SS
Manufacturer: Crosley by GE
Type of Appliance: Dishwasher
Model Number: XDT500PSP4SS
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES
Crosley by GE - Dishwasher
Mod# XDT500PSP4SS
Ser# FR775947B (Mfg.Dt. Mar.2020)
Need tech sheet or preferably a service manual the describes the operation of the water level pressure switch.
This one doesn't use the standard float switch that has problems, (It uses a Analog to Digital pressure transducer like on newer washers).
No water fill - maybe a bad valve but need to be prepared to check pressure transducer if valve is OK.
Posted (edited)
See if you can use this service manual:
Maybe this mini manual:
Edited by Captain Dunsel
@Captain Dunsel Thanks that looks like it should work - looks just like the Crosley model I will have to look at.
