JennAir JMC8130DDS stopped heating
Our microwave just stopped heating.  The display/control panel works; you can enter a time and it will count down and beep when done. The light inside also turns on, and you can hear a relay click.  However, the turntable doesn't turn, it doesn't heat, and the blower doesn't start.
Any thoughts on what's wrong, or what to check first?
Thanks,
Steve
  • MrApplianceMatt
  • Vance R
  • lustreking
The interlock switches for the door.
I agree. You likely have a bad door switch and it that's the case, replace all 3 switches, 2 door switches and 1 interlock switch, and the holder they live in.
