    • 15 March 2025 02:00 PM Until 03:00 PM
      When: Saturday, March 15 @10:00 AM Eastern Time.
Manufacturer: Kenmore
Model Number: 106.4641173713
Looking for the tech sheet and schematic diagram for this unit. Issue I’m having ice maker is not making ice. Fill valve is not receiving 120vac from the ice maker when it runs on normal setting or force harvest. We’ve replaced the ice maker with a new one but still not working. Since I couldn’t find the tech sheet I can’t identify the wires but from what I can see ice maker has four wires in the harness Black (L) White (N) Brown (Line from ice maker to valve) Green (Ground). I am getting 120vac to the ice maker from Black (L1] White (N) and I do have continuity from the White to Brown when I place my meter on the fill valve plug and jump the two on the harness inside the freezer with my jumper.
  • Captain Dunsel
  • Chris0719
Uses the same one as these models:
That tech sheet and model number should be similar to this service manual:
  • 2 weeks later...
Thank you.
