Alliance Speed Queen AWN43RSN115TW01 washing machine won’t drain all the way.
Washing machine drains until there’s a little water left and then blinks error code “wash spin 2 times” I replaced the load sensor. Still giving the error code.
  • 2 weeks later...
  • evaappliance
  • chilsonhc
Not getting water out quick enough, should be pumping out in a minute or less , if not , check for things like suds, objects partially obstructing pump, or drain if the hose is sealed to the standpipe.
I drains just fine. There are no obstructions or suds. It just quits draining and gives me that error code.
then check the out of balance switch and wires
