Manufacturer: Ghermador
Type of Appliance: Range
Model Number: PRG366GH/13
Hi all, I have a Thermador oven that works well when set to 350 and under but if set to anthing above 350 including broil the indicator light goes out. It looks like I was also getting an error code the "oven on" light flashing twice and "Preheating" Flashes once
Im looking for a service manual and parts manual please
Do you have access to the service side of Bosch?  All of the service manuals are in their technical documents there.  Quite a helpful resource if you work on Bosch often.
Here is an error code chart I found, depending on the order of the LEDs you either have ec 12 or 21.  Is the oven on light on the left or right?  if it is on the left you have 21, if it is on the right you have 12.
Hope that helps.
Thank you so much. Yes, extremely helpful!
The oven light is on the left, so looks like a Pontentiometer failure.
How is one granted access to their service documents?
Thank you @kjolorenzen
We can actually provide Bosch info -- here's what I've found for your model:
It uses the schematic from this bundle:
And these docs:
