Click here to take the quiz.
Manufacturer: Maytag
Type of Appliance: washer
Model Number: mat20csaww1
This is a commercial washing machine in the laundry room of a big building. I went their and the drain pump was just sitting there disconnected. I tested it and it was froze up. I replaced it and find water leaking from the water valve but something else is going on. It wont agitate or spin so I would like to do diagnostics on it
  • Replies 4
  • AllStarBob
  • Captain Dunsel
Uses the same tech sheet as this model:
Thank you Captain I believe that tech info lines up with my unit but the contols are different. I'm attaching a picture of the unit I have. The problem is I can't do the key dance to get into diagnostics. Any insight would be appreciated.20230228_125721[1].heic
Ok, Thank you
