ASKO W6222 Washer Stacking Question
etherhuffer
Our old W6222 washer had 2 clips in the back to connect to the stacking dryer. The washer is dead, getting a new one. ASKO said we could likely stack the old dryer on new machine. Well, the new machine has one clip in the center, not two spaced 13" apart. Anyone ever deal with this?
  • etherhuffer
  • Nathaniel Peterson
No, but you could most likely drill new holes being careful that there's nothing behind where you're drilling at. Then use the old brackets if they line up to screw into each other. As long as it is secured it should be fine. Do this at your own risk though. As long as you have something to attach to that doesn't affect other parts of machine operation.
etherhuffer
Yes, that is what it looks like. We got a new design clip, need to put two holes in the old dryer. checked clearances and guts of machine, not an issue. All is well. Thanks for the reply!
