Wolf Dual Fuel 30 inch Range/Oven Control Knob
etherhuffer
Our oven control knob is getting finicky. This is a 15 year old range, already had the relay board for oven replaced a few years ago. The temperature light does not illuminate in the knob. Oven won't start. Tripped the breaker and waited, then tried it. No go. Popped open the control panel and went through a few settings, then tried knob again and it kicked in. Not sure if knob electronics are dying or a more central board. Any ideas?
  • etherhuffer
  • Nathaniel Peterson
Probably just a glitch in the board. Just reinsert it and/ or cycle power off for 30 seconds. Knob is controlled by erc and main board not relay board. Try nolox or whatever it's called behind molex connectors to help keep moisture out. Only enough to coat backside of connections.
etherhuffer
Sounds good. Ever used DeOxit on these boards? The main boards get kind of grungy in there. We already lost a relay board from a dry relay leg.
