DFE28JMKBES Freezer ice maker not getting water
I have a GE Adora Fridge/Freezer DFE28JMKBES.  Suddenly the freezer ice maker stopped making ice.  The fridge door icemaker works just fine and dispenses water and makes ice normally.  The freezer ice maker is not filling the tray with water, which is why it obviously stopped making ice.  I have defrosted everything overnight and it didn't help.  I have replaced the water valve that feeds the water to the freezer ice maker and no luck.  Finally I have replaced the main control board and that didn't help either.  Upon further investigation, I know the hoses aren't clogged as I checked the hose from the valve to the freezer.  It looks like the water makes it into the filter fine through the tube, but there is another tub coming out of the filter area that feeds the valve then feeds the freezer ice maker.  That tub that comes out of the filter never pushes water.  I disconnected it and turned on the ice maker and the water never even gets to the valve.  Anyone have any thoughts?  I am out of ideas at this point.  I would assume it has nothing to do with the freezer ice maker as it simply isn't getting water.
Thank you for any and all help!
Joe
  • Replies 1
  • Vance R
  • joepreg
The most common failure for the freezer icemaker not filling it the fill tube freezes.  If the fill line is clear from the Y at the back of the refrigerator into the freezer you'll need to check voltages at the freezer i/m valve and the isolation water valve when the freezer icemaker call for filling.
