mike arvada
I replaced the temperature sensor and oven in bake mode is still not holding temperature.  It is fine in convection mode. Which of the two circuit boards are the oven controller board?  That is the next item I am going to replace unless someone has a better idea where to hunt for the problem.
Mike..
  • mike arvada
  • Josh Smith
be a little more specific. Does it get to temp at all?
mike arvada
During preheat it gets to temperature, but does not maintain it.  If set for 400 it will come to 400, then center around 340 degrees.  Sometimes it will go to 390 on one "on cycle" and then go back to 340 for a few cycles, then 360, but mostly centers around 340.
Mike..
