DCS - DCS RG-484GG Gas Range - Electriciy completely off "most of the time"
I have a  DCS RG-484GG  range and there are no fancy electronic displays, or switches. All of the power seems to be dead. I cycled the breaker and still no resolution.
The strange thing, is  that occasionally the power will restore, but it doesn't last. And its either all the power or none of the power (all of the lights, convection oven fan, led's will either be all on or all of).
Does anyone have advice as to what is happening or how I should start diagnosing? The range is very heavy and will be hard to move away from the wall.
  • Replies 1
  • fkcfkc
  • MrApplianceMatt
Posted Images
You definitely have a power supply issue. I would check the breaker itself and see if that's failing or has loose connections behind the panel. Otherwise I'd pull it away from the wall and check the receptacle/junction box and then the power cord itself.
