Manufacturer: Kenmore
Model Number: KLBH031ATE
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Y
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Y
Looking for the water inlet valve. My search pulls up about 3 part numbers so not sure which one I need.
The whole valve and flow sensor is  60154-0006100-00 sears shows nla, encompass part is b/o status and is expensive $209.95. The valve by itself is 60154-0002501-01 sears and encompass show nla. The flow meter is 60148-0001701-01 sears shows 44.88 in stock and encompass shows 46.95 b/o order status.
Most of the time the leak is from the flow sensor.
  • Like 3
  • Thanks 1
  • 8 months later...
EXACTLY THIS!  Clear plastic gets brittle I guess & springs a small leak.  Many thanks!!
  • 3 months later...
Hey Vance, Darren412 here. I was wondering if you might have any input on this valve assembly and if there was any way of by-passing this flow meter that is leaking , since the parts are NLA.  I have come to the conclusion that this valve assembly with flow sensor 60154-006100-00 will definately not be found. I have researched the flow sensor and valve separately and found those to be NLA also. If I was able to by- pass this flow meter . I am thinking this fridge will throw a flow meter error of some kind and then shut down the fridge or shut down the water flow in the system some where. I would love to find a way of by passing this leaking flow valve and still have the ice production and water dispenser operating normally ??  Any thoughts on this vance would be greatly appreciated . thanks Darren412
Those parts have been nla for long time.  My best swag would be to use a bosch part which shows in stock sporadically at internet suppliers.
  • Like 3
thanks for the response Vance . This was a situation that I really wanted to be able to help this particular customer with. I really appreciate your input in helping me to make this happen. This site is lucky to have you 😉
  • 1 year later...
  • 2 months later...
Had this exact call today.  Invaluable info here!
