New Appliance Service Manual added: GE Washer Serial numbers: SM - DS ( September 2019 - February 2021) Software Update Service Bulletin
View File
PUB HL06-21
Models GFW510SCN0WW
GFW550SPN0DG
GFW550SSN0WW
GFW650SSN0WW
GFW650SPN0SN
GFW850SSN0WW
GFW850SPN0DG
GFW850SPN0RS
GFW510SCN1WW
GFW550SPN1DG
GFW550SSN1WW
GFW650SSN1WW
GFW650SPN1SN
GFW850SSN1WW
GFW850SPN1DG
GFW850SPN1RS
Symptoms: Pedestal Vibration, Unbalance Load, Wet Loads, No Spin,
Unresponsive User Interface Buttons, Unresponsive After
Applying Over The Air Update, Drain Pump Turns On
When Washer Is Not In Use
  • 4 months later...
  • Son of Samurai
  • Dwbingham
I am working on this washer GFW550SSN1WW
I can hear a relay on the board (or something like that) switch open or close and then the machine will cut off. After changing the control board, I was finally able to get it in service mode, but the problem persisted.
shouldnt a new board solve the software issue?
Please post this question as a new topic in the Appliance Repair Tech Help forum. That will make it easier for folks to find it and give you advice.
