Fisher & Paykel induction cooktop C1905DTB1
Go to solution Solved by J5*,
Good evening all,
Hoping someone can help me out.  The filter board pcb assembly blew on our induction cooktop.  I ordered a replacement board from Fisher & Paykel ( Eco75.96470.751).  Fitted the new board, powers up but comes up with error code 31.  I’m hoping it’s a simple configuration setup for the new board?
Thanks in advance.
simon
  • Replies 8
  • J5*
    5
  • Kurnol
    4
Posted Images
There ya go
you are correct its a config issue
ive had limited success when doing it
good luck
Thanks JS I’ll give it a go tonight
I never saw they have a video as well , might be worth a watch
the secret button process is what is tricky
some units i did it just didnt work and product was changed over
Hi J5,
My cooktop is a series 1 rather than a series 2.  I managed to get into the configuration menu by holding the lock plus any of the other buttons.  After 1 beep you press the the far left minus key.  There’s 8 options in the first set of controls plus 3 on the second set.  Any chance you have the info for the series1?
Your a legend!
