Hello I am working on a Kenmore 106.51762 510 circa 2015.  This unit is a SXS Whirlpool with an evaporator in the FF section.  The FF evaporator fan is intermittently not running.  It will stop for a day of so and then run for about a week just fine.  The FF section stays at about 50 when the fan doesn't run.  I installed a new fan as I had 14 VDC at the fan plug when I tested it.   But it is still doing the same thing as before.
Thank You
  • Tilmon33
  • ServiceTech_Daniel
Are there any reasons for the board to shut the fan off.  Open door? Or evaporator temp? For example.
ServiceTech_Daniel
You have a fresh food compartment thermistor and a  evaporator thermister . If either is out of spec the board can tell the fan to shut off , or you may have a bad Gemini board.
I would start by checking the thermistors with your meter by doing a voltage drop test at the board. You should have 5vdc
Or remove the thermistors set them in a glass of ice cold water for about 5 minutes with the tail end out and take a ohms reading (your tech sheet should have the temp reading chart on it .
If the thermistor check out good you might have a bad Gemini board (main control)
