Bosch HDI7282C/09 Dual Fuel Range Burner problem
I have a Bosch HDI7282C/09 Dual Fuel Range and it cannot get up to temperature when the bake element is used. I works ok when to top broiler element is used.
I have replaced the thermostat but that did not help.  I am now trying to get a replacement bake element.  Every on line appliance part supplier says the part is no longer available.
Does anyone know of a source for Bosch Bake Element part number 00491571 or is it possible to get it repaired somewhere.
  • Replies 7
  • PeteMJ
    4
  • Nathaniel Peterson
  • MrApplianceMatt
I'm not sure how the wattage compares, but this is a hidden element for a Samsung range that looks to be the right width and spacing for the terminals...DG47-00020B.
Thanks for the suggrstion. The Samsung burner appears to be 3kw but i think the Bosch part is 2kw. I am still looking for exact specs for both to compare.
Just now, Nathaniel Peterson said:
See if this works
i clicked on the "buy now" link and it opened up ebay  and it says it is  "Sold Out" .
Looks like there's other compatible part numbers maybe you can try that?
Yes, i am searching all the part numbers, nothing found yet.
