AlaskaErik
When trying to light a burner I hear it sparking at what seems to be a different burner.  It can take a while before it finally lights with a big poof.  How do I get this to fire off on the correct burner?
  • AlaskaErik
  • 16345Ed
  • Nathaniel Peterson
All igniters spark when one is calling for spark because all the spark switches are wired in series. Usually you want to clean the burner head with a wire brush. Where it sits on,  clean and dry that also. Make sure burner head is on properly and check igniter for cracks. If there's a cracks it'll shoot the spark at the closest piece of metal closest to the crack. If that all checks good then you either have a grounding issue on ignition module or the wire coming from the spark module and burner.
99.5% of time it’s just a dirty burner, gas flow obstruction.
