Manufacturer: GE
Type of Appliance: Fridge
Model Number: GSRS5KLZAFSS
GSRS5KLZAFSS GE Fridge Tech Sheet / Service Manual Needed please. I need the forced defrost instructions which are not included with the wiring diagram on GE's site.
I'm not finding anything for that model number, unfortunately.
I would re-check the model. Something don't seem right.
Maybe there just is no tech sheet
Thanks, I am aware of that site but neither of those had any defrost instructions either. What sort of service kit are you referring to?
This Canadian Model maybe like some of thees old Arctica Profile Models!   All the GE electronic refrigerators have a Diagnostic Mode that is incorporated in the software in each main electronic board. This Diagnostic Mode will test certain components and operate others.
To activate this diagnostic test feature on an electronic refrigerator, you will need a touch pad control with at least 5 key pads; otherwise you will have to install the additional diagnostic tool.
  • Thanks 1
I'm sure that knowledge will be useful in the future, thank you
  • 1 year later...
I was looking for this model as well as did find the tech sheets. I tried to attach, but it says pdfs are not allowed. Strange. So, here is the link to the tech sheets:
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://visualizador.serviplus.com.mx/datos_pt/refr/manuales/WiringDiagram_31-51661.pdf&ved=2ahUKEwj80eHckqCKAxV3D1kFHfs-EHIQFnoECBgQAQ&usg=AOvVaw0Q2VGTB5YHlDSaXWsszbUD
Thanks, @jharmke! We also have that doc here on the site:
By the way, if you want to upload a PDF file in the future, you can do that by going to the Downloads section and clicking the Submit a file button.
