GE ZDBC240NBBS Beverage cooler/refrig Compressor overheating
Hi
   I have a beverage cooler that turns on . Compressor starts as does the fan next to the compressor.   Cooler is working fine and getting cold . A few hours later the unit has stopped . Dead!      Compressor is hot.     Let it cool and it starts up  and runs .
Any ideas
  • Replies 4
  • bubba153
  • Captain Dunsel
  • MrApplianceMatt
  • Vance R
Could have a bad start device trying to run both windings at the same time. Beyond that I'd have to lean towards failing compressor or low on refrigerant and it's working overtime to keep up.
Hi    Thank you    for the info.   is the start device you mentioned the capacitor?
Thank you
This would be the part is is talking about General Electric WR07X10072 RELAY START
If possible need to know the running amp draw of the compressor.  Also need to know the LRA ( locked rotor amp) rating from the tag on the side of the compressor.
