Manufacturer: MAYTAG
Type of Appliance: DRYER
Model Number: medb850wq0
Problem Statement (State what is the appliance doing that it should not be doing, and what it's not doing that it should be doing.): Will not run, lights, press poower button clicks will not run.
What diagnostics have you already done?: Tested fuse, belt is ok switch works, door switch is ok, belt is good
Service , Parts and diagnostic manual required.
Mike
@Microns You ask for service manual in the wrong forum! Uses this wiring diagram:
This tech sheet:
This service pointer:
If you want Parts List go here:
Go to servicematters Limited Access. https://servicematters.com/en_US
Put your model number in where it says part number and then click on Parts List and download it.It is free for this!
@Son of Samurai Here is another one in the wrong forum if you want to move it or leave it be.
Thanks, Captain -- yes, I've moved it.
@Microns, please make sure that you're posting manual requests in the Manual Requests forum in the future.
Thanks for the quick response and corrections, I will move it.
Mike
