Manufacturer: Whirlpool
Type of Appliance: Range
Model Number: WFE535S0LZ0
Serial Number (optional): R94613722
Problem Statement (State what is the appliance doing that it should not be doing, and what it's not doing that it should be doing.): Not baking
What diagnostics have you already done?: Tested bake element resistance at the control board, very high 266 ohms, should be 20- 40 ohms.
Need service manual for this model range so I can replace the hidden bake element. The oven bottom is not removable and I dont see the bake element terminals from the back.
I don't have the manual for this one but I think this is hidden in the side. You have to pull one of the side panels off to access it. I had one like this last year and I had never seen it before. The harness had melted on that one and caused the board to fail.
Uses these tech sheets. @tcmeyer14, I moved your topic to the Manual Requests forum, which is the proper place for manual requests. Please pay careful attention to which forum you're posting in and what that forum's purpose is.
Thank you Team Samurai. I will pay better attention next time.
