Speed Queen Front Load Washer PARTS manual request.
Manufacturer: Speed Queen
Type of Appliance: Washer
Model Number: AFNE9BSP116TW01
Can’t find online a parts manual. Need a parts diagram please that clearly lists and points to parts on diagram. Customer complaint is that washer is shaking like crazy. A bracket in the front that secures the bottom washer weight to the floor appears to have broken off and gone for a hike. Screws fell out and three are missing. Can’t find a parts manual online or website that clearly illustrates parts locations. There’s also a product code on this one - Product code: FF7008WN. Please see pics. Thank you!
you probably already tried http://speedqueendoc.net but just in case, listing that option here.
Oops, you’re right! Please forgive me. I had gone there, but I guess I was not  persistent enough. Found it. Thank you!
  • 1 month later...
Thats a shipping bracket that must be removed. Installer error.
On 7/28/2023 at 1:05 PM, MATTS said:
shipping bracket
Thanks for your response!
I had figured that out once I got a hold of the parts diagram - my bad 😞 for not touching base sooner. Like I had written earlier, customer was complaining that the machine was shaking like crazy. I had gone back there and had them test it with clothes and made sure that it was well anchored to the ground -  appeared to test good. So I closed it out, only to get called again - recommended expensive repairs which they weren’t to keen on - end of story for now. (In the back of my mind was wondering if that shipping bracket had never been removed from the beginning and so the customer got used to operating the machine with that bracket attached which kept the machine from shaking as much - then once the shipping bracket broke off the drum the machine started shaking a lot and alarmed the customer. Who knows?!)
