Whirlpool Side by side Frig/Freezer (Model WRS315SDH202) is leaking water into the bottom of the freezer...once the water fills the bottom and freezes, water leaks out onto the floor.
desertdad46
How can this be remedied?
  • Replies 1
  • desertdad46
  • HiLife
2 possible causes:
1) Do you have an ice dispenser on the exterior of freezer door? If yes, check the flap seal. If warm air has a pathway up thru the dispenser it will cause thawing; water runs to the bottom & freezes, when the ice builds & reaches the door it will thaw on the edges and leak out.  Often ice in the bucket will become a solid block sue to thaw/re-freeze.
2) are the heating coils collecting frost? Is there frost build up elsewhere?
The defrost mechanism is blocked. There is a drain hole in the floor of the freezer under the heat coils - if this gets blocked condensation won’t drain & will pool & freeze (same eventual outcome as #1 scenario.)
It’s an easy fix - but getting to that drain may take some effort - mine is behind a panel - consult a diagram of ur model.
unplug power before accessing & be mindful of coils, they will be extremely hot even when covered in ice.
