    • 15 March 2025 02:00 PM Until 03:00 PM
      5
      When: Saturday, March 15 @10:00 AM Eastern Time.
Like new Bosch 24 speed oven shuts down clock back 12
Bosch Speed oven micro combo 24 inch 20amp service.  What is something I should look at replacing if unit shuts down when trying use.  Does not seem matter broil,micro,both shuts down like power turned off then back 12 oclock
  • Replies 4
  • seagul
    4
  • Nicholsseand
Is your oven on a dedicated circuit? It could be tripping if you have a hood vent or something of the likes on the same breaker
I did just redo 20 amp service 12/2 see if that solve issue.  I did notice main feed ti condo unit had 100 amp master breaker in crooked?  Possible issue we never tested original oven 220 before bought dumpy place.  Some say door switches go bad on these.  Complete shut downs quite quickly.  Breakers never trip only oven.
I may head over condo yank this out so work on it home.  Inspect power wires on back feed see burnt.  Any burnt wires around door switches maybe test those volt meter.
Ok found thermo cutoff burnt wire replaced now works.  Once pulled out obvious what cooked.  Now wondering why failed maybe pros chime in
