Whirlpool undercounter ice maker only makes 1 batch of ice, passes diagnostic tests.
Model #GI15NDXZS
It passes all of the diagnostics test, has good water flow to the unit, senses water level in reservoir, compressor and condenser fan run and fan moves good air. Evap plate has full frost pattern after a few minutes, hot gas valve switches and melts frost, max ice led flashes after a few minutes showing evap came up to temp. I removed and cleaned the compressor start relay, it looked ok with just a little carbon. The machine still only makes a batch of ice or 2 then quits making ice. Any suggestions? Not sure if this matters but the UI software version test, the on/off light blinks 7 times, no other lights blink and the ACU software version the Cleaning complete light is on and the on/off light blinks 3 times. Thanks
  • Replies 0
  • cleanrf
