PRD48WDSGU/02 Thermador Range
grecoaierdale
I have a Pro Harmony Range driving me crazy. It threw a control board code E601. I had a technician come out to trouble shoot. He had no idea what was wrong. I followed his suggestion to replace the control board, which I did. It was still not working. I replaced the steam oven display with no change then the right display which partially fixed the problem. The steam program no longer shows any recipes and will only work for 25 minutes at a time. The main dial temperature indicator will stop working until I reset the oven from the breaker. If I try to use the temperature probe it causes all kinds of problems with the oven. Last night it started turning on and off even after I reset it at the breaker. I eventually set the steamer and oven to to 350 degrees and convection bake after which it reset itself and started working again. The stove top along with the griddle has worked with no problems.
I would be eternally grateful for any help.
  • Replies 0
  • grecoaierdale
