Miele G5675 Futura Dimensions Water Intake Error
spartacusmcfly
Posted 3 hours ago · Hidden - This content must be approved before it can be edited.
I'm having the following issue on a Futura Dimensions G5675 scvi.
Issue:
1. Water Intake error (no code)
2. Machnie runs the pre-wash smoothly (about 15-20 minutes)
3. Water is entering unit, pump is circulating, water is spraying in every corner of unit if I open mid-cycle
4. After pre-wash, it drains water and tries to begin the main wash cycle.
5. At this point, it beeps and displays a water intake error
What I have tried so far:
1. Replaced the entire intake valve
2. Replaced the entire intake braided hose from under the sink (in case it was blocked)
3. Thoroughly cleaned the sump area and the mini-impeller behind the removable casing.
4. I'm assuming the main pump impeller isn't blocked as it successfully completes the pre-wash
Other ideas I'm considering:
1. Changing the water inlet Reed Switch connected to the salt tank
2. Replacing the run capacitor (available from Miele for $35)
3. Unfortunately, Miele lists the Reed Switch in the parts diagram but doesn't sell it online.
4. Thoughts on how I can get the Reed Switch? (Miele part #6185800)
Other ideas?
  • Replies 0
  • spartacusmcfly
