LG LRFCS2503S not cooling, 3 red flashes on PCB
LG LRFCS2503S unit stopped cooling, getting 3 red flashes on PCB unit, metered out compressor terminals, terminals to ground are good, but not reading from terminal to terminal, not sure what the linear compressor readings should be?
  • Replies 4
  • Richbahama
  • Econo Appliance
  • Vance R
  • ServiceTech_Daniel
Posted Images
ServiceTech_Daniel
if your getting 3 blinks and resetting it doesn't work , you more likely have a bad Compressor .
Compressor terminal reading's should be
Power 6.6 - 7.6 ohms
Save 9.1 -10.5 ohms
Lg changed the naming to power , save and common for the terminal names instead of Start, Run , common
Ok, sounds correct, no reading what so ever between the terminals of the compressor unit, very odd
  • 1 month later...
I just had one of these also with 3 led blinks (not listed in service manual)
I also had no ohm readings on ANY of the compressor terminals.  Told customer to call LG under limited compressor warranty.
This is a rare linear compressor, it has sense tap for the coil.
 3 blinks is a stroke trip.
Check the connections, harness, capacitor and compressor winding to each other and ground.
