    • 01 March 2025 03:00 PM Until 04:00 PM
      When: Saturday, March 1 @10:00 AM Eastern Time.
Manufacturer: Electrolux
Type of Appliance: Laundry Center
Model Number: Flce7522aw2
I have the tech sheet. I need the service manual to help me test individual components.
  • Dewalt83
  • Captain Dunsel
This video is from Electrolux site on the You Tube.No service manual on the Electrolux site.
Thanks Captain. Sure would be nice to be able to know how to test each component. I've got one being very weird.  The customer complaint was no spin. So i put it in diagnostics test 7. (Normal) Lid locks. Spin for 25 seconds while draining water from the tub. When i did this the lid locks and drain pump starts.Then  you can hear the motor trying to spin but it sounds like its in bind. I know the shifter is working properly. One because I watched it engage, but also i could turn the agitator freely and then once I saw it engage the hole drum would spin when I spun the agitator.That tells me the shifter is engaging. I could here it trying to spin so I helped it get started and it began to spin but at a very low RPM. When I picked up the top of the washer with the lid closed and locked it put a little pressure on the wire connections to the lid switch it would get slower and faster. This is why I'm thinking lid lock switch but can't seem to find a way to verify my hypothesis. Only thing I know to do is replace lid lock and hope for the best.if you have any insight that would be great .
