I used to be WP authorized 25 yrs ago. Looking at a WRX735SDBM00, S/N K31102082.  Unit has a leaking primary water valve, also called an isolation valve. It is shown on the wiring diagram, but not on any of the parts breakdown drawings. There is no part number found on the valve its self.  This is a F/D 3 door R/F and working well except for this leaking valve that caused extensive damage in her kitchen.  Any help locating a part number would be appreciated.
  • Replies 6
  • John Mc
    4
  • 16345Ed
  • Vance R
Part number should be on leaking valve.
As I stated, there is no part number found on the valve itself.
As I stated, none of the diagrams show this part. It is between the ref water line and the wall water line.
Yup not listed on the parts diagram, found this at sears parts direct:
  • Thanks 1
Thank you so much, Vance. That looks just like the beastie I need.  In stock at local supplier, too. THANK YOU.
