Bosch dishwasher shem63w55n/10 not powering on
Hello, I have a Bosch shem63w55n/10. It does not react to any bottoms and doesn't power on. The control module is getting 120V to it, I checked. No visual damage to the module, user interface, wiring. I replaced the power module with 12016880 Power module programmed (does it mean it comes pre-programmed and does not require any special programming?). Same thing, not working. Next, I replaced a user interface board 11012411 controller unit, no results. I checked all the wires that go from main control board to the user interface with a multimeter - all good. What am I missing, anyone knows? Thank you
  • 2 weeks later...
  • Replies 1
  • Chris.s
  • Antonymaks
Antonymaks
Did you fix it?
