Need GE Dishwasher TECH Sheet
Manufacturer: GE
Type of Appliance: Dishwasher
Model Number: GDT655SFL4DS
Hello folks,
If someone can help me with GE dishwasher tech sheet. Model - GDT655SFL4DS
Also I will need help with as the lower spray arm is spinning fine but upper arm is not when both lower and upper zones are selected.
But when only upper arm selected, it is working fine then.
I feel like if it is driver valve problem then how is the upper arm working when just upper zone is selected. If anyone ever face this issue with help me.
Thank you.
Maybe similar to this manual:
Uses the same mini manual as this model:
  • Thanks 1
Thank you Captain Dunsel for sharing those tech sheets.
Would you happen to know how I can fix the unit when the lower spray arm is spinning fine but the upper arm is not when both lower and upper zones are selected?
But when only the upper arm is selected on the UI board, it works fine then.
I have ordered the:
WD26X22826 Circulation Pump Kit &
 WD18X21678 Diverter Valve Kit.
Thanks for your help.
I have ordered the:
You need to ask that Question over here:Appliance Repair Tech Forum
