  • entries
    862
  • comments
    1,398
  • views
    2,722,539
How to enter quick test mode in a Maytag electric double wall oven
RegUS_PatOff wrote:
Follow procedure below to use the quick test mode.
Entries must be made within 32 seconds of each other or the control will exit the quick test mode.
1. Press and hold CANCEL and BROIL pads for 3 seconds.
2. Once the control has entered the “Quick Test” mode, release both pads.
3. Press each of the following pads indicated in the table below.
NOTE: First time one of following pads are pressed it will activate the response.
The second time the pad is pressed it will deactivate the response.
Display will indicate the following:
Pad Response
BAKE................................... Bake DLB and Bake relay activated
BROIL.................................. Broil DLB and Broil relay activated
KEEP WARM ...................... Bake DLB and Broil DLB activated
CONVECT BAKE ................ Convection Fan on high speed
CONVECT ROAST ............. Cooling Fan activated
CLEAN................................. MDL relay activated
COOK & HOLD ................... Displays last diagnostic code
FAVORITE .......................... Displays EEPROM version number
TIMER ................................. Displays main code version number
CLOCK................................ All display segments illuminated
OVEN LIGHT.......................Oven light activated
CANCEL.............................. Exit Quick Test mode
1........................................... Even segments on
2...........................................Odd segments on
3........................................... Convection Ring activated; Convection Ring DLB activated
4........................................... Bake relay activated
5........................................... Broil relay activated
6........................................... Convection relay activated
Source: Maytag electric double wall oven MEW6630DDS is only beeping and not functioning
1 Comment
AUTOSET button ................. Steps through last 5 diagnostic codes
