How to Find the Model Number Even When it's Missing
One of the first things you need when you start working on an appliance is the model number. Otherwise, unless there's a tech sheet with the machine, there's no way to find technical info on it. But what do you do when the model number tag has been damaged or removed? It's a rare occurrence, but one that can cause a major roadblock in a repair. Here's an example of one such situation:
As you can see, both the model and serial numbers are almost entirely illegible. Fortunately, there's a simple and easy trick thought up by the clever @Art4corners to circumvent this problem -- scan the barcode!
For anyone with a smartphone, this is simple enough to do. Just download a free smartphone app, such as this one that Art4corners used, and show it the barcode. That will show your model number plain as day.
One of many smart solutions to tricky problems discovered by one of the sharp techs at Appliantology. Want to join their ranks? Click here to become a tech member today.
10
3
.png.9012a87f3d9d47f1728530e9414b5964.png)
5 Comments
