    257
    839
    558,346
Would you Troubleshoot this Washer Motor Problem the Right Way?
Do you know the most efficient way to troubleshoot this washer motor, or would you go through unnecessary disassembly? Watch this webinar excerpt to find out.
This is just a short excerpt of a webinar that's packed with even more vital info on how to maximize your service call profitability through solid troubleshooting techniques. Click here to watch it now. This and 50+ hours more of awesome webinar recordings are available only to our premium members at Appliantology.
2 Comments
aonanwerhi
should have been the motor, but since the drain pump is connected to the motor and does drain, then I'll suspect somewhere in the transmission
salscamaro
I would assume it's the motor coupler given that it does drain, which indicates the motor is running bit not turning the tub.
