    257
    839
    558,165
Most Techs Wouldn't Troubleshoot this Door Switch the Right Way...
I want you to take a look at the door switch I've circled below. Think about it for a minute, then answer one question: what single test could you do to prove beyond a doubt whether or not that door switch is operating within spec?
There's no trickery going on here -- it's just a simple switch. But many techs will test it using a flawed, limited test that has a big chance of leading them to the wrong conclusion. And they'll do a bunch of unnecessary disassembly. Post your answer in the comments below!
Want to check your answer? Watch our in-depth technical webinar which covers this troubleshooting scenario and many other circuit puzzles, including:
- Some pop quizzes about series and parallel circuits
- Diodes, how they work, and the surprisingly tricky situations that can arise because of them
- Loads in series, how they work, and what they look like in a real refrigerator schematic
Click below to give it a watch! This webinar recording is only available to premium tech members at Appliantology and Master Samurai Tech Academy students and alumni.
18 Comments
Raynormensk
The dryer won't run if the door switch is open, so a good test to confirm the door switch is remaining open with the door closed, is to select a cycle, and try starting the dryer running. If it wont start, that confirms the door switch is remaining open. The motor circuit cannot be completed without a closed door switch.
PlanB
I would measure the voltage from L1 and J3-2.
Although all that’s true, you’ve not proven anything. This is just restating the original problem statement. You have not proven that the door switch is the problem and not the main board (which, BTW, the tech replaced with no joy).
There’s an even easier way that doesn’t require a meter. Hint: jumper wire.
JohnnyCage
Use a jumper wire to connect the orange to brown wire connection on the door switch?
You’re on the right track. While that would work, you would need to remove the front panel to install the jumper. There’s a more clever way to do it right from the control board and all you have to remove is the top panel.
JohnnyCage
Jump J2-3 to J3-2?
  • Like 4
MVrepairs
Besides feeling the door switch with your hand and listening for the click; start the machine (or try to start it, move the timer and hit start) and do a voltage check on the board. Check J3-2 in respect to J2-3.
2 hours ago, JohnnyCage said:
Jump J2-3 to J3-2?
Yes!
  • Thanks 1
Ricky Bobby
Nice work Johnny. Of course.... thank you Master Samurai.
  • Thanks 2
Krohns
Does it run with door closed?
MarcusF
Posted (edited)
Jumper J3-2 to J2-3. If the door switch is the problem this will turn off the "door open" light.
Is J2-3 just looking for the presence of 120V WRT to Neutral after the thermal limiter but before the door switch?
Edited by MarcusF
Yes, J2-3 is a sensing line like we’ve seen in the Samsung and LG dryers (and other appliances). Excellent!
Pop quiz: What’s the functional difference between J2-3 and J2-4?
MarcusF
It seems to me like J2-4 is the 120VAC power supply to the board while J2-3 is, like we established, a sensing line.
You got it, Toyota!
Slav
On 11/25/2020 at 2:46 PM, JohnnyCage said:
Jump J2-3 to J3-2?
If jumping the Door Switch doesn't work, we can assume the Outlet Thermal Limiter is open. So we could jump J2-4 to J3-2 to bypass both the Door and the Thermal Limiter... right?
Yes, but you probably wouldn't even need to assume. The fact that J2-3 is a sensing line for a computer means the computer's OS would likely be programmed to pick up the open on J2-3 and throw an error code.
Correctillia!
fillthebarman
I’ve jumped the motor relay to show that is bad a few times.
