Testing Knipex 85 51 180A "Spring Hose Clamp Pliers" vs. ERP KP-2 Hose Clamp Pliers
After @Pioneer's recent post looking for recommendations for spring hose clamp pliers, I decided to try what, judging by the price ($67.99, delivered), I figured must be the Cadillac option; the Knipex 85 51  180A (smaller of 2 sizes, 10" big brother are Knipex 85 51 250 A, both of which Knipex describes as  "Spring Hose Clamp Pliers")
tl;dr - They're okay I guess, but I think they're intended for single-wire spring hose clamps, not the double wire type that we typically see in appliances.
Inlined here is a short video I made comparing their use on double-wire spring clamps against the venerable KP-2's I've also included a pic of the back of the retail packaging, showing images of 4 types of clamps that Knipex states they're intended for use on.
I'm still considering firing up the mini metal lathe and welder, making some higher-quality versions of the KP-2s using actual Vise-Grips.
Edited by Rhubarb Tau
3 Comments
vee8power
Thanks for posting this! I tried a couple different hose clamp pliers before I found the KP-2's. They worked better than anything I tried before until the hands-free clamp feature started failing. If I need to, I guess I'll put zip ties around the handles to hold  them, like I do with my cheap hose pinch pliers.
Rhubarb Tau
Same, that's what's so frustrating about my KP-2s, they used el-cheapo vise grip clones, so they barely lock. Still the best I've found, but frustrating that they aren't better
fillthebarman
I replace the spring clamps with screw down hose clamps most of the time.
