    3,443,110
How to fix a Samsung dual-evaporator refrigerator where the beer compartment keeps icing up
This fix is for the Samsung-built refrigerators (includes some GE's) with two evaporator coils: one in the freezer compartment and a second one in the beer compartment (most refrigerators just have a single evaporator coil in the freezer compartment).
The problem here is that ice would be left in the condensate drain pan after defrost (see below) which would build up to a solid chunk of ice.
Here's a clever, low-cost solution:
well I am back as prommised... great news....
well after 2.5 months I can say it is a fix indeed. I never lasted 6 weeks and the normal was 3 weeks.
so if you are giving up with all fixes because everything works like mine did but always froze up do this. do the soldering when the fridge is off. here are some pictures.
this one shows the ice left after a defrost cycle, this should not be there. It is a problem. you can see to the left it doid melt some ice, but there is still a section that is just going to keep building because it did not melt through a complete defrost cycle. I have higher resolution pictures at a link at the bottom of the post.
below is the 2.2 k ohm resistor in series. do it with power unplugged. just cut one yellow wire close to the connector and solder a 10 cent resistor in and tape it
here is a modification to the heat sink. I added some aluminum flashing to make contact on both heater bars to transfer heat to the lower part to melt the ice. make sure you have a curve contact on the bars for better contact area. not shown is I have a tapered small tab on that flashing that also goes into the drain hole to make sure the drain hole is kept from being frozen
I also added a heat sink to the left, it was not making good contact with the sheet metal, so I made a piece that made more contact and stopped it from being a hot spot. which could cause that area to burn out. they tried to do it all with the rivited points, that just is not a lot of contact area.
I bought the aluminum flashing at Ace hardware, but bet you can get small sheets at hobby shops.
here is a bending of the upper tabs to make better contact and allow the water to drop to the bottom during the defrost vs handing on after the defrost and freezing and adding humidity. i only did this on the top row. i did not bend the one on the left yet and you can see the water droplet right behind it.
here are higher resolution photos if you need them click below
fridge
Source: defrost failure samsung model RS2555SL
1 Comment
tcmeyer14
There is a heater kit that can be installed. NOTE: It is not a Samsung OEM approved part or procedure
