    3,455,351
Frigidaire FEE368CCSD Range display blanks out
A grasshopper posts:
This started about 2 weeks ago that when the oven is turned on the Electronic Oven Controler goes blank that show the oven functions. The oven does not heat up in any mode. I can redo the inputs several times with the same results. Has the EOC failed or do i need to look at other parts of the unit?
Source: Frigidaire FEE368CCSD Range display blanks out
This is a bad electronic control, slam dunk. Come git you one... 00853543.jpg
1 Comment
billywilly
I have a Frigidaire FES355EBC. works great until it beeps once and shuts off the oven leaving a blank screen on the EOC. Turn a surface burner on and the clock flashes 12:00. You can then reset the clock and the oven works until this happens again. Sometimes within mjnutes, sometimes the next day. any ideas on this? I have just replaced the EOC and still have teh same problem.
Thanks.
