    3,455,326
How to remove the dispenser on the newer model LG refrigerators
Example model number: LMX25981ST
Grab your flavorite fermented beverage and sit at the feet of the Academy's LG sensei:
Per LG training...
Explain to the customer that---removing the DISPENSER ASSY *will* sound as if you (the servicer) are rough/unprofessional.
When removing the entire Housing---loud snapping sounds are produced.
This is normal.
1) Slide forward and remove the drain tray (place finger(s) at the back/rear and squeeze locking tab)
2) Grasp the bottom of the DISPENSER HOUSING and firmly pull towards you (plastic straining noise will occur)
3) Working from the bottom---move to the lower edges and continue pulling/unsnapping the Housing Assy.
4) Since the DISPLAY is situated on the left side of the Housing---all wire connectors are on the left side.
5) Re-installing is much easier than removing. Apply effort to be certain that the Housing is fully snapped in place.
NOTE: Again---per LG---it is NOT uncommon for one or two plastic *tabs* to break when removing the Housing.
This was designed to still adequately be installed---minus a locking/snap tab or two.
Explaining this to your customer will eliminate their concerns---and you'll be a thought of as a professional because you
took the time to explain all of this to your cusomer *before* starting your repair work.
Not much different than having a doctor that tells a patient bluntly:
"Yes, this needle *will* hurt,but the medicine that I'm injecting is the cure for what ails you".
Buy parts for your LG refrigerator here with a 365-day return policy ==> http://www.repairclinic.com/LG-Refrigerator-Parts
Source: LG LMX25981ST refrigerator -- man'l req and disp. problems.
2 Comments
Derik
Awesome tip!! Sure I'll run in to one sooner or later? What was wrong that dispenser needed took off though??? Curious now!!!
Me, too! Follow all the exciting developments in this problem here ==>
