    3,454,779
Appliantology Newsletter: The Art of Troubleshooting
August 12, 2012
Presents another award-winning issue of...
zenzoidman_appliantologynewsletterheader
The Ancient and Mystical Art of Troubleshooting
A long, long time ago, people did things like read books instead of surfing the Internet or had thoughtful discussions about complicated topics instead of yelling political slogans and sound bites at each other. Most folks also had at least a conceptual understanding of the process of troubleshooting: the logical, step-by-step progression of tracking down the cause of a problem.
To troubleshoot an appliance, you first need to have a basic understanding of how that appliance is supposed to work both from the operator's standpoint and how the components inside are supposed to work together. In other words, to figure out what's wrong, you first have to know what "right" is. Then begin troubleshooting right at the problem and step through, checking inputs and outputs, whether mechanical or electrical.
For example, an oven electric bake element isn't getting hot and is not visibly damaged. The element needs 240 VAC to get hot, 120 VAC at each of its terminals. The voltage at the terminals is controlled and delivered by different circuits or components inside the oven. Many people would just immediately replace the element, not even considering how the element works or checking to see if it's getting the voltage it needs to operate. Maybe they get lucky and fix the problem, but that's not troubleshooting. That's changing parts like a monkey.
Appliance repair servicers who practice their trade like that are not technicians or Professional Appliantologists; they are called "parts changing monkeys."
Parts changing monkeys can cost you a lot of time, frustration, and money.
Beware the Parts Changing Monkey!
What's a parts changing monkey, you ask?
He (or she) is someone who knows how to change out parts on your appliance, but doesn't know how to actually troubleshoot the problem. Based on your problem description, he will change out the most obvious part involved and hope that fixes the problem. That works just often enough to get by in many repair situations, but there are other times it results in a major rip-off of the customer.
Here's a repair saga where I followed up behind a parts changing monkey who never bothered to troubleshoot an overfilling complaint on a GE front-loading washer. He had replaced two parts without fixing the problem and was trying to convince the owner to replace a third. I was called in and quickly found the actual malfunctioning component that monkey-boy failed to even check. It's not rocket science! You just need to have a basic understanding of how these machines work, and that information is readily available in posts like this:
Wisdom! Let Us Attend!
You can find whatever appliance part you need through the parts search box at The Appliantology Academy. No harm in buying and trying with our 365-day, no-hassle return policy, even on electrical parts that were installed!
I'm always uploading new videos to my YouTube channel of my real-life appliance repair adventures that I do in people's homes. I film, produce, and upload all these videos completely from my iPhone so they're not all professional and slick looking but they are enlightening. You can keep up with 'em by subscribing to my YouTube Channel.
You can get more repair tips by liking our Facebook page.
Samurai Appliance Repair Man, www.Appliantology.org
