    3,455,360
How to Replace the Recirculation Tube in a Whirlpool Calypso Washer
Part link for the Recirc Tube ==> http://www.repairclinic.com/PartDetail/Tube-water-recirculation/8054989/903391
The basket *does not* need to be removed. Raise the top, take off the tub ring. Release the tab on top of the recirc tube where it anchors to a slot at top of the outer tub, and pull the tube straight upwards to remove it. Press the replacement tube down into place on the connector nipple/nubbie at bottom of the tub, anchor the tab. Reassemble the tub ring and machine top.
Thought I would finish this post.........
Hose barb in the tub.Just wiggle, twist and lift, pops right off...........Sprits on some Windex, align spout and wiggle and push down...........pops right in..................This was the hardest part......
..........Getting the 'nib' / 'protrusion' all the way into the slot and engage retaining hooks...................More Windex and work / pull the hooks into the slot...........
