    3,454,615
Replacing the Inner Basket and Drum Bearing in a Whirlpool Duet Washer
Brother Strath talks us through these tulips using the Whirlpool Duet washer model WFW9400SU01 as an example:
here's the short version:
- Remove everything from the tub front and back. (Shocks, hoses, pressure hose, bottom hose, ground wires, drive belt, motor, pulley - but leave the bellow still attached, just disconnect it from the washer front.)
- Pull the weights off front and back to make it lighter. (Tub's are about 53 lbs with all weights removed.)
- Lift the tub out the back (you might disconnect the top brace that holds the valves and lift it up to make it easier.)
- With a Sharpie, mark where the clips are on both halves.
- Remove all the clips and separate out.
- If you are doing this because of a bad bearing, you have to replace the rear tub as well.
- Don't forget to gob up the new bearing with the supplied grease ... and don't forget the new gasket that goes between the tubs
- Put the halves back together - you may have to pinch them together with Channel Locs to get the first couple of clips back in place
- Reassemble
- Double check that all hoses have been connected before testing.
Beer time.
Parts:
Inner Basket
Rear Drum with Bearing
To learn more about your washer or to order parts, click here.
Source: model # wfw9400su01
