    3,455,315
Maytag Performa washer thrust bearing re-assembly order
If you ever have to replace the thrust bearing, basket drive hub, or snubber in one of these Maytag Performa top-loading washers, you may get the washers and spacers that comprise the thrust bearing out of order. Brother fairbank56 has put together this nifty roadmap showing the proper sequence for re-assembling the thrust bearing.
If you boogar up or lose these parts, you can buy the replacement kit here: http://www.repairclinic.com/PartDetail/Basket-Drive-Hub-Kit/12002213/1042142
  • Thanks 1
