Click here to take the quiz.
    3,455,338
Wall Oven Wiring Fail
I went to remove a wall oven today and ran into a little problem. Can you find it?
I run into this kind of problem all the time up here in the backwoods of New Hampster. It's an endemic problem with electricians and handymen not bothering to read the installation instructions. For the record, this installation fail was done by a licensed electrician. Kind of a wake up call for the whole licensing racket, isn't it? Having a "licensed" electrician is still no guarantee that he knows what in the hell he is doing or is capable of reading simple installation instructions.
In case you're interested, you can read the manufacturer's installation instructions yourself here: http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318206002.pdf
BTW, those specs are typical for all manufacturers.
Bottom Line with any wall oven installation: You need to have enough slack in the power wire conduit to be able to remove the wall oven from its compartment.
  • Like 7
12 Comments
skintdigit
How then, Sensei, did the Sparky wire the thing up and replace the junction box cover???
Elementary, my dear skindigit.  Sparky wired the wall oven first, with it outside the cabinet.  He then pushed the length of wire and cable conduit down the hole into the basement where the junction box is (instead of the proper location inside the cabinet cubby with the oven, as shown in the installation instructions).  Then Sparky pushed the wall oven into place, went down into the basement and pulled remaining slack out of the conduit.
Sparky never considered the prospect of the wall oven having to pulled out for service (hidden bake element on this one, wall oven has to come completely out to replace it) and apparently thought this wall oven would last forever and never need to be replaced.
Sparky's story is, unfortunately for the customer, a common one.
richseattle56
And again, it is no wonder they call you Samurai!!!!! Sparky didn't have a chance.
Sparky called me yesterday and, to his credit, he's going back out this Friday to amend the error of his ways.  I'll go in after to do the repair: replace the bake element (hidden element, replaced from the bottom, entire wall oven has to be pulled).
RedToryTy
Could be worse. You could go out on a wall oven Hammer the Genuis Carpenter pinned into the wall, unable to service with damaging solid red oak trim. The home owner needed a thrice explanation about why I couldn't repair her oven. Made me wonder about both of them.
AARDL
Samurai,
What wise device do you use for a stand for wall ovens.
Domo
I use the venerable All Dolly.
And my teenage son.
Ty2010
Interesting, my first guess would have been new install style with the junction box attached to the cabinet back immediately below the drawer bottom.
Pulling the fridge and end panel from the cabinet not an option even though it's a non visible area? On that note, you wouldn't believe what's been volunteered as a sacrifice to get an oven fixed the day before Christmas or Thanksgiving.
Nyet, tovarish.  Home boy ain't about to jump around his elbow to get to his azzhole because the electrican did a non-spec installation.
So I do it this time.  What about the next time this wall oven needs service?  Same Chinese fire drill?
That ain't the answer.
The solution is to get the installation up to the specifications that it should have been installed with in the first place.  Then the unit can be serviced both now and in the future.
splinterexpert
How did you diagnose the hidden element vs an internal wiring failure?
Son of Samurai
Not exactly sure how that's related to the bad oven installation, but this is exactly the kind of troubleshooting magic that we teach in the Fundamentals course over at the Master Samurai Tech Academy! If you want to learn how to never get stumped on a job again, this is the course for you. Click below to check it out:
https://mastersamuraitech.com/appliance-repair-courses/fundamentals-training/
bna12122
I see this type of faill all the time and people don't want to call their electrician to fix the problem.  I can usually diagnose the issue without pulling the unit forward through the magic of appliantology.  Sadly it takes extra time and costs the customer extra money to do something that could be easily resolved if only someone read the installation instructions.  Electricians, plumbers and cabinet people are notorious for not spending the extra 5 minutes needed to review what needs to be done before doing it.  Which in turn always makes our job more difficult.
