applianceman97's Blog
    18
    45
    82,952
Whirlpool Coin Op VMW Washer Model drain pump runs and runs even after unplugging.
I couldn't find this issue in the archives. The lid is locked, light on solid. It continues to run the drain pump even after unplugging and plugging back in. I cannot enter the diagnostic mode. The green light on the control board is on. I lifted the top and noticed the clothes in the washer were dry and loose so this problem must have occurred before the washer filled.
Info from Brother Adirondack Bob,
Per Tech Line from a call I had a couple months ago-
Voltage to the washer was lost for whatever reason.
When power is re-applied the Drain Pump will run for 6-9 minutes.
If washer is unplugged and plugged back in, pump will start over and run for 6-9 minutes again.
Solution is to let pump run until it shuts off on its own.
Source: Whirlpool Coin Op VMW Washer Model CAE2743BQ0
  • Like 3
1 Comment
Shaphan Hawks
This just greatly helped!
