Refrigerator Troubleshooting Quiz Entry posted by Samurai Appliance Repair Man January 8, 2015 3,906 views Share https://appliantology.org/blogs/entry/807-refrigerator-troubleshooting-quiz/ More sharing options... Followers 3 When you're ready to check your answer, click here.
Team Samurai Samurai Appliance Repair Man Posted January 9, 2015 Team Samurai Glad you like 'em, Walter. What's the answer?
Patricio Posted January 10, 2015 Both compartments warm, I be checking if compressor is a running along wit da fan hoss Obvious no cooling taka place wid out comp doing it job
Team Samurai Samurai Appliance Repair Man Posted January 10, 2015 Team Samurai Both compartments warm and condenser fan running-- compressor would be my next stop!
AQAppliances Posted February 28, 2016 I would check the freezer wall first and foremost. Check for possible defrost problem or fan issue. No way I am starting by pulling the refrigerator out and checking the condenser fan motor.
Team Samurai Samurai Appliance Repair Man Posted March 1, 2016 Team Samurai On February 28, 2016 at 6:56 PM, AQAppliances said: I would check the freezer wall first and foremost. The flow chart starts with both compartments warm. Even in a defrost failure, the freezer would be "cold"-- not necessarily 0F, but still cold. At this point, you know there's a problem with the sealed system-- either compressor not running or refrigerant leak. Why waste time tearing apart the freezer?
Rich Armstrong Posted July 19, 2023 I thought the answer would be: While your are already looking for a functioning condenser fan why not break out the IR gun and get the the temperature split at the middle of the condenser and room temperature. We are looking for a difference of at least 20*. If not there is a failure in the compressor or a Freon leak! 1
7 Comments
