    3,455,315
Why do antiphase sine waves cancel each other out in a sound mixer but not in a center-tapped transformer?
This is an excerpt of the full split-phase household power supply webinar held on June 6, 2016. In this excerpt, I explain why antiphase sine waves (meaning 180 degrees out of phase with each other) cancel each other out in a sound mixer but not in a center tapped transformer. Just because an AC voltage can be represented or modeled as a sine wave does not mean all sine waves behave the same way everywhere regardless of the device-- you have to know what you're measuring!
References:
Summing Amplifier Basics
How Sine Waves are Used to Model things in the Real World
Using an Oscilloscope to Understand 120 VAC Household Power Supplies
