  2. Today
  3. Electrolux Frigidaire #FFLE3911QWD
  4. Maybe it would nice to share with us as it may help someone else in the future.Go here:direct link to the uploads page: https://appliantology.org/files/submit/?do=submit&category=3
  5. Frigidaire stacked washer & Dryer. Lid lock solenoid has 105ohms across the solenoid and checks out as OKAY. I am getting 120v at the "L" and at the "lock input" terminals at the board, with no lock plugged in. I was expecting 120v at the "L" but the lid lock should be nothing until the solenoid is energized and closes the switch to send 120v to this terminal. Washing machine won't start and the lid is not locking after I press the cycle selector/start dial.
  6. Got one from Perlick, Tech guy was very helpful.
  7. Manufacturer: BlueStar Type of Appliance: Refrigerator Model Number: BBB36L2 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): No Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hi there! Looking service manual for BBB36L2. FF coils freezing up. FF fan works, there is no visible defrost sensor, so a bit confused how its defrosting coils. Any help or suggestions highly appreciated. p.s. originally we replaced heat exchanger and evaporator on ff side, due to leak in heat exchanger. Charge done by manufacture label and coils freezing up only at evaporator and not any further.
  8. Son of Samurai
    Bosch HBL8454UC/02 service manual needed
    Uses these docs:
  9. Mucho domos, Captain!
  10. GE Dryer Personality Program Procedure WE22X36578 Part Install Instructions View File Pub 99-3000285 Rev. 1 Submitter Captain Dunsel Submitted 05/19/2025 Category Appliance Repair Manual Pot Luck Supper
  11. Speed Queen ZDE6HRYS177CW01 Troubleshooting Manual Dryer View File Pub Service Manual D518686ENR4 Pub Wiring Diagram D518182 ADE3SRGS177TW01 ADEE9RYS177TW01 Information in this manual is applicable to these dryer models: ADG6HRYS117TW01 ZDE6HRYS177CW01 ADE4BRGS177TW01 ADG3SRGS117TW01 ADGE9RYS117TW01 ZDEE9RYS177CW01 ADE6HRYS177TW01 ADG4BRGS117TW01 ZDE4BRGS177CW01 ZDG6HRYS117CW01 Submitter Captain Dunsel Submitted 05/19/2025 Category Appliance Repair Manual Pot Luck Supper
  12. Manufacturer: Bosch Type of Appliance: Range Model Number: HBL8454UC/02 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Service manual and diagram needed . please and thank you
  13. Captain Dunsel
    Need complete service manual
    Double check that model number!
  14. Manufacturer: Frigidair Type of Appliance: French door fridge Model Number: Frfg723av03 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Need complete service manual, found tech sheet
  15. Anyone ever seen this type of issue with Samsungs?
  16. Version 1.0.0
    0 downloads
  17. @Centre St-Exupery I just got this service manual that is current and also a copy of the wiring diagram.Uploading and waiting on approval:
  18. Kvberry13
    Control board Repair pics
  19. Yesterday
  20. MrApplianceMatt
    Personality Codes...Where do you find them?
    It should be listed in the tech sheet taped to the inside of the washer, otherwise, here's a breakdown I found... https://www.manualslib.com/manual/1254374/Ge-Htw200ask_ww.html?page=44
  21. Working on a GE top load washer Model # GTW460ASJ9WW serial #LL142320G. I have seen some say the personality number is 11 on this model and also seen some that said it was a 3. Anyone have any idea what personality number this washer may be. It would check something off my troubleshooting list if any one knows. I have checked it on the service mode and it appears as three. Thanks in advance for any advice.
  22. Been researching this type of pressure switch far and wide and came up empty. (I bought another pressure switch from Bosch just in case- different design, with a factory-set adjustment screw under the housing which is held on with 3 tabs.) I'm going to try to make the tube longer. The nipple on the pressure sensor measures about 7/32" (.217"-.218") so that tells me 3/16" ID tubing will work with a 3/16" barbed connector. Just trying to figure out where do I put the slop so it doesn't chafe or get in the way. The original tubing is this black rubber star-shaped tubing, but I will extend (and not alter) with standard vinyl tubing.
  23. Rich Armstrong
    Service Manuel Request
    Thank you Captain
  24. GE Washer Personality Program Procedure WH22X32817 Part Install Instructions View File Pub 99-3000259 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
  25. GE Part Instructions Wi-Fi Module Kit WH22X33297 View File Pub 99-3000273 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
  26. GE Washer Personality Program Procedure WH22X37219 Part Install Instructions View File Pub 99‐3000379 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
  27. GE Washer Personality Program Procedure WH22X38440 Part Install Instructions View File Pub 99‐3000379 Submitter Captain Dunsel Submitted 05/17/2025 Category Appliance Repair Manual Pot Luck Supper
