  2. Manufacturer: Fisher & Paykel Type of Appliance: Dishwasher Model Number: DD24DCHTX9 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Hello! I seen the manuals that show up for this in previous posts but I cant get into service mode using it. The "Lock" feature uses two buttons on this model unlike the others. Thanks for any help!
  3. Uses this manual: The schematic in this bundle: The check routine request and error codes in this bundle:
  4. Today
  5. Uses this manual: And this parts list:
  6. Thermador T42BT120NS/02 Refrigerator Parts List View File Thermador T42BT120NS/02 Refrigerator Parts List Submitter Son of Samurai Submitted 07/02/2025 Category Appliance Repair Manual Pot Luck Supper
  7. Version 1.0.0
    0 downloads
  8. Son of Samurai
    Tech sheet
    Domo, Captain!
  9. KitchenAid KRFC300ESS07 Refrigerator Tech Sheet View File Pub Tech-Sheet-W11542405-Rev B Submitter Captain Dunsel Submitted 07/02/2025 Category Appliance Repair Manual Pot Luck Supper
  10. My fridge the other day was getting salad greens icy at back of fridge. To be honest, fridge was completely packed. This morning, freezer contents were defrosting, even though LED for freezer said -2. Clearly NOT -2 in freezer if ice cream melting. I cleared out stuff from fridge and freezer. Ran a blow dryer in back of freezer to make sure no ice. Unplugged fridge, waited, plugged back in. LED then read 46 for freezer when I plugged back in…but after a while, eventually went back down to -2. But thermometer in freezer reads much warmer. Can the ok LED temp shown be wrong? When I put my hand inside freezer, it doesn’t seem as cold as LED reading. (Inside fridge temp is same as LED reading 38) The refrigerator section seems to be working fine. How long, if freezer components working properly do I have to wait for freezer temperature to be correct? (since I’ve been constantly checking the freezer, the LED temp has risen to 1. But Taylor old fashioned thermometer inside freezer reads 30—which is 16 degrees lower than LED read when plugged back in) By the way, I can hear refrigerator is running. I am just trying to determine if this might be on the road to recovery or get help…which on this holiday weekend might be impossible! thanks.
  11. will check, thank you.
  12. There is really no exact manual for this! Uses the same wiring diagram as this model: Indoor ice maker: This may not apply but here you go:
  13. Manufacturer: Kenmore Type of Appliance: Refrigerator Model Number: 10656546400 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for complete service Manual and tech sheet for 10656546400 , Thank you!!
  14. Couldn't agree more with this! Great job @Nathaniel Peterson! You've certainly earned this badge, and I continually enjoy reading your input on the forums. You've got a lot of sound knowledge, wisdom and experience!
  15. Manufacturer: Bosch Type of Appliance: Dishwasher Model Number: SHS43CF5N/01 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Looking for diagrams, etc. to help with a not powering on issue. Will light up on breaker cycle, 5 seconds, then go out and won’t power on. SHS43CF5N/01
  16. It is possible that it is bad. The specs may have something you can find for a resistance check. I've never herd of the shifter causing the no lock issue before, but its either gonna be lid lock or board. Veryfi that its getting power from the controller. if its powered and not locking then switch, if your seeing drops in power when it should be locked then board.
  17. Casualcamo
    Have you looked at any fans?
  18. Casualcamo
  19. Casualcamo
    Tech needed in Hammond La
  20. Nothing here!
  21. Not that I could find.Uses this tech sheet:
  22. Version 1.0.0
    0 downloads
  23. Captain Dunsel
    Tech sheet
    Uploading tech sheet and waiting on approval:
  24. Budget Appliance Repair
    @bldn10 Well...... That would certainly cause your problem - Glad you finally got it figured out.
  25. Budget Appliance Repair
    I would still be concerned about those capacitors - I don't think that is glue to hold the capacitor to the board. I think it's the guts of the capacitor that have leaked out possibly).
  26. I have a 4 year old whirlpool wrf555sdfz french door refrigerator. Noticed ice maker not making ice. I changed the water filter, water pressure increased and I was making ice. Then noticed the refrigerator was getting too cold (freezing my beers). Getting to about 25 degrees. I cleaned the coil and fan underneath (I removed front grill and back cover, vacuumed and blew the dust out). I am getting ice bucket temperature of 14 degrees. The bottom freezer is getting a steady temp of -4. I have the refrigerator temp set to 37 and freezer set to -5. The refrigerator temperature appears to be stabilizing around 36 degrees. But getting very little Ice. I read that I need to be at 10 degrees in the ice bucket to make ice. I have read about an issue with the ice maker filler tube freezing up. So I entered diagnostic mode , test 38 (forced defrost) and changed it to "Lo" for long defrost. Also the refrigerator seems to run all the time. I wake up in the morning and its running after the doors have been shut for 7 hours. Let me know if there is something else to try
